Sent you a PM back.
I don't have a part number. It is the slave that is provided by LSC in their current kits. Call Brian at LSC and I'm sure he can provide the right number.
That is a Quicktime bellhousing. Part number is 6060 for a 351W, which is the engine I'm running. Since you are using a 428, you will have less room than me. Still, if you fab a bracket, you can make it work.
I'm still building so I haven't tested my setup yet. I don't anticipate any problem though. When bleeding, the bleeder nipple will be on top so I can get all the air out of the cylinder.
Randy
