  #33 (permalink)
Old 06-02-2010, 08:25 PM
dlampe's Avatar
dlampe dlampe is offline
The motor is on a bit of a delay. He is a good friend of mine and he is having some medical problems that the doctors have been unable to diagnos. He said he would get it done if I had to have it. I have been giving him some space to finish up some of the more important engines in his shop. I'm going to continue finish up some of the options before I make the call to him and ask for the engine.
I am going to start on the sway bar system. I plan to run a bar front and rear. The trick is to maintain the adjustability. Like the springs, the sway bars have a large efect on the wheel rate. The important thing is to always know where your set up is so you can make adjustaments that are repeatable. Here is a calulator to help establish where you are with your system.
http://www.circletrack.com/car_racin...tor/index.html
I am using a solid 32 inch bar on the front and a 34 inch .090 wall hollow bar on the rear. Here is a picture of the parts.
High Maintenance Racing Team
Run & Gun 2003 - 2013
