Jim,
I've also had some problems with my slave-cylinder for my tranny. I bought a replacement part from NAPA and installed it on my TKO tranny. Unfortunately, I installed it so that the rod going to my transmission was at an angle that pushed the piston inside my slave-cylinder at an unusual angle. This caused the piston inside the slave-cylinder to lose fluid because of the unusual angle pressed upon the piston inside the slave-cylinder. I had to grind off a tab on the slave-cylinder to make it adapt to the TKO tranny. I've been problem-free since then.......knock on wood.
Shawn Smart
Component Craft #18
1966 427 with a 390 FE bored over .40
