Old 06-07-2010, 08:55 AM
nicko_esx nicko_esx is offline
hello sr.ozgur
told him that I got plans and templates to build the body, with similar method to you. your post is very helpful to me.
in Argentina there is a problem for the patenting of cars made outside the factory, so I'll have to build it on another car, such as the Ford Falcon or Ford Taunus Argentina. example http://www.todofalcon.com.ar/Fotos/66_princ.jpg
I found out similar cases in Argentina's construction on other cars. but these cars do not have chassis are minivan, I will use parts of the subframe and the reforzare. removing the entire hull.
the engine initially using a 6-cylinder in line, until a V8.
suspension will be modified. we use double-acting shock absorbers short.
well then I will continue posting. in these weeks we started to build a scale model for debugging techniques. I'll post the results
thank you very much to everyone's attention. especially to mr. ozgur.
