Old 06-08-2010, 05:44 AM
Zedn's Avatar
Zedn Zedn is offline
Default Jag rear handbrake route?
Hi Guys,
I am installing my hand brake at the moment (jag rear). I have to mount the handle on the centre consul because there is no room on the right of the seat. The problem is that with the inboard brakes the cable has to come in from the side. Basically you end up with a very small cable that needs to loop out and back in the side.
I am using the Lokar handle and 'you cut to size' cable.
How i have it will work ok, but it is sort of jammed in there. I just thought i would ask how others have run the cable with inboard brakes. For those that arent familiar with the Jag set up, the two levers are pulled together to activate the brake meaning that the outside of the cable has to be able to move.
Any opinions are welcomed. Pics of other would be great.
