Old 06-08-2010, 09:01 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Default Scoop-whole pic. story
This scoop was made on the car and is now being prepped to make a "Buck.
Painted, waxed, release agent, now the matt....
Removed from the original scoop- this is now the "Buck'
Scoop & Lower valance in Gel-Coat
Buck now glassed in place-waiting 24Hrs - In the Back ground, hanging up is the original custom hood mounted and waiting for the Customers car.
The NEW scoop covering the stock scoop-from the rear
New Scoop from the FRONT- Look carefully you can see the OEM scoop showing up on the inside..
(QUOTE0 By the way it is just over 1/4" higher than the "Cobra" Air cleaner and is about 1 1/2"s wider on both sides for engine movement. When I pop the mould I'll get the full measurements. This should fit the Hi-Preformace Plastic "Hartman" Intake box as well as the Cobra R Manifold! First one that orders a scoop (?) I'll take a series of photos on how to install it on your car just for the mailing cost and the cost of the scoop. If you have basic body skills this has been made to be quite simple!
