Old 06-12-2010, 06:04 AM
Barry_R Barry_R is offline
Eljaro is correct.
Usually dieseling (or after-running) is caused by excessive closed throttle airflow. This is when the carb idle speed setting is too high. The fix for this can be more base timing, which allows for closing the butterflies up while retaining the same actual idle speed. One really light spring in the distributor can be used to allow a lower timing setting during cranking that instantly jumps up a bit once the engine fires up.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
