Somehow, you need to make room under those carbs for a phenolic spacer. That will probably cure most of the hot start problem and is the cheapest/easiest way to start.
The fuel in your bowls is boiling after shutdown. I had to get a drop base air cleaner to clear my hood once I put the spacer on, but it was worth it.
Jim
