Thread: No Oil Pressure
Old 01-05-2002, 03:23 PM
poorboy poorboy is offline
Frank;
It shouldn't make any differance which way you run the oil threw the cooler. Did you install a remote oil filter at the same time, or change the lines? The filter has a check valve in it. Did you change from a standard filter to a hi-performance one. The standard filter usualy has just a flap for a check valve that most oil pumps can overcome. Some filters have a steel check ball that the pump cannot unseat during reverse flow.
Poorboy
