Thread: Superformance
Old 06-13-2010, 09:52 PM
timsullivan's Avatar
timsullivan timsullivan is offline
Cobra Make, Engine: Superformance SPO2820 408W; former ERA CCX 3-3408 owner
Default MSD Distributor works fine with Superformance Duraspark ignition module
Its not necessary to eliminate the Duraspark module as they are fully compatible with the MSD distributor. I used the MSD Pro-Billet Small Diameter Street Ford Distributor PN 9478 for my 351W based 408 stroker motor and spliced the two wire MSD distributor connection into the existing Superformance wiring 2 wire harness for the distributor and it works fine. No MSD ignition module needed and the MSD distributor is fully compatible with the Superformance factory installed Ford Duraspark ignition module that comes pre-mounted in the passenger footwell.
