Old 06-14-2010, 05:14 AM
strictlypersonl strictlypersonl is offline
Originally Posted by Rwillia4 View Post
Have you bleed the brakes? I'm guessing air in the line or caliper. Once it heats up it expands and rubs. Is it still rubbing now that cool?
There is a bleed port in the master cylinder that allows fluid to run "backward" whenever the master cylinder piston is fully retracted. If more calipers were locking up, I would have speculated that the port was blocked, but in this case it obviously isn't.
Khansmith's problem is likely a loose or misaligned caliper, malfunctioning emergency brake mechanism, or a sticking caliper piston.
