Originally Posted by IMLost
302 that i just stroked
How new is the engine? How bad is the drip.seepage?
Are you running any kind of PCV system? FYI, relieving any block pressure through a PCV system or better yet an evac system will greatly reduce any tendencies for seepage.
I had a similar issuie after taking great care in the setting the rear seal, and still had a small leak. However, after a few hundred miles and running a closed PCV system the leak went away.
It depends on how sever the leak.
Goos Luck!
