Originally Posted by blykins
The flywheel bolt hole is a thru hole on the later model stuff. It goes all the way through the crank flange and could leak oil if sealant is not put on the bolts.
yep, and he says it's a 302 based stroker motor, all the stroker cranks I've seen have the holes going thru the rear crank flange.....
David
