Old 01-05-2002, 10:34 PM
R&B R&B is offline
Bob,
Thanks for the help. I pulled the white wire and you are correct, I do not really need it. Unfortunately it turns out that the resister gets hot when I turn the ignition on before I start the car. It takes about 30 seconds to glow red. Fortunately, I decided to start the engine anyway and the resister has no problem when the engine was running. My guess is the under wire dash. I never really figured out how to wire the Smith tach. The tach seemed to work during the engine break in period until I turned on the lights (I was trying to hit the fan) and the tach went to zero. I was also anxious to break in the engine since it was rebuilt awhile ago (a long while ago) and so I cheated and did not connect the back wiring harness nor do I have any exterior lights. Unless you have any obvious ideas, I think I will finish the wiring, restudy the tach and try again later.
Thanks again.
