Drill the floor directly under your butt. I used a 2" strap from the original harness (now have 3") with the strap's steel attachment that went on the bulkhead.
Under the floor I used 4" square steel plate, 3/16 thick. Install grade 8 bolt from top and use stover nut on bottom. Be sure to use a washer under the bolt head so the belt can swivel slightly.
Chas.
