Old 06-19-2010, 12:25 PM
Rick Parker's Avatar
It is possible that you will have clearance issues with a 351 and that manifold. Check the dimensions on the Edelbrock site. You will definately need to use a drop center air filter assy. I used to run that intake on a 289 and had about 1/4" clarance with the top of the air filter and the edge of the cutout for the hood scoop. Good manifold, need a lot of cam and good compression and double pumper carb.
Rick
