Old 06-21-2010, 11:38 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default oil pressure w/ bypass spring
ok quick question, hopefully this is easy.
By changing the spring pressure to a stronger spring in a oil pump, will it
A) increase pressure
B) decrease pressure
C) nothing at all
D) increase the limit for when the pump will bleed the oil back into the crank case.
Please describe your answer, and remeber that many aftermarket oil pump sellers sell a different spring ( for what?)
