Originally Posted by tony martin
THE PIPE SIZE IS NOT YOUR PROBLEM.
I AM GOING TO TAKE A FLYER HERE AND SUGEST:
CHECK THE STROKE OF YOUR MASTER CYL.
IT SHOULD BE 36-37MM AND WHEN THE PEDAL IS DEPRESSED MAKE SURE THAT IT BOTOMS OUT ON THE M/CYL.
SOME OF OUR CARS SLIPED THROUGH WITH A 32MM STROKE M/CLY.
THE MANUFACTURER DID NOT ADVISE US.
THE MIN. TRAVEL (MARGINAL)THAT U NEED TO ENGAGE WITHOUT GRATING IS 32MM
IF U HAVE 1 OF THE 32MM M/CLY JUST CALL REG AND I WILL SEND U OUT A NEW ONE.
Did you actually read the post, not just the title? No one said the pipe size was the problem.
