Old 06-23-2010, 06:34 AM
madmaxx madmaxx is offline
Default FMS 427 Sroked Small Block Thoughts
What do you guys think? It has a meaty cam @ 576 / .600 lift with a rocker arm ratio of 1.65. They are cramming the air into those cylinders.
Retail is $8800, what I see to finish is:
1) MSD distributor $219 plus $42 coil + $15 for hold down = $276
2) Edelbrock Intake manifold $299.95 + $20.00 gaskets = $320.00
3) Alternator $100.00
4) Pulley $200 plus bracket for alternator $100 = $300
5) PCV valve $5 plus throttle plate = $50.00
6) Fuel log for carb and fuel line from fuel pump = $100
7) Carburator = $370.00
8) starter $100 hardware to mount $15.00 = $115.00
9) Fuel pump = $40.00
Total cost before labor to finish engine assembly = $8800 + $1617 = $10,471 Throw in $500 for labor and you are at $10,971.
