Original Style Frame W/Fiberglass Body?
Hey all
For those of you who are building an original style frame and using a glass body, what do you do about the cockpit edge tubing?
The body isn't going to be able to "bend" around the tube frame unless that tube is cast into the body, right? Then weld the frame together once the body's mounted? How do you deal with that?
Alba gu brąth
