Originally Posted by flipscobra
has anyone had trouble with the helicoils pulling out, mine did I had to have an insert put in it, it pulled out of the stand on number 1 cyclinder, an it hell getting head off in the car when it has studs.
yes and yes, also the intake threads. pull the heads and put inserts in all the threads. don't trust the edeldork locations either mine were off up to .025.
i had to skim the heads on the intake surface also to get them square to the dowel holes. what a pain, next set of heads will be blue thunder or pond.
our machine shop can fix them up for you if you don't have anyone to do it.
fred
info@origincorp.net
