Thread: Need appraiser
  #39 (permalink)
Old 06-25-2010, 07:21 AM
Fordzilla's Avatar
Fordzilla Fordzilla is offline
Cobra Make, Engine: 1969 Mustang Fastback Pro-Street, constantly changing ongoing project!
Use bronze wool and I like automatic transmission fluid. You can find bronze wool in several grades (I use the medium and fine) at hardware stores. Sine you are new at this start with a fine grade. It may be all you need anyway. Bronze is harder than rust but softer than steel. It won't remove patina & original finish if you go gentle & use common sense. The ATF helps to soften the rust and also prevents it from scratching. It is also one of the best anti-rust gun oils.
Mick
(Of The Troops & For The Troops)
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body; but rather a skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, WHAT A RIDE!"
