Old 06-25-2010, 03:21 PM
dcdoug's Avatar
dcdoug dcdoug is offline
Originally Posted by jolsen42 View Post
It looks like they are PRO shocks. To lock them in place there are two small holes in the adjustment rings. After you've reached desired height, insert a piece of wire through one of these holes and wrap around the first coil of the spring, and the adjustment ring. Bring both ends together and twist tight. Cut off excess and bend out of the way. Hope that helps. John O
That's what I'm looking for. I knew there had to be a way that this was designed to work. I will look more closely for the holes (and may be back if there aren't any....)
Thanks!
www.partskeeper.com
