Old 06-28-2010, 05:57 AM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
I was thinking the same thing...loose the mechanical pump. Is it carburated? If it is then make sure your power valve is working. If you blocked it off you might want to put it back. Make sure your secondarys are opening..again if your carburated. Another guy asked what size your fuel lines are...make sure your filter isnt installed backwards...seen that before. Depending on what type of filter you have..some dont flow worth a damn when installed the right way and wont flow at all if in backwards.
Just some thoughts.
Gene
" If it wont break em loose in 3rd gear, it aint enough power "
