  #28 (permalink)
Old 06-28-2010, 01:47 PM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
Smile
Originally Posted by IMLost View Post
FYI my rear seal leak is still a mystery. My engin in fact had a 2 piece seal installed into a 1 piece block. my theory is that whover built it put the crank on a lathe and cut a groove after they found out they messed up!
Dont understand the crank in lathe, cut groove bit, the only way I can see that a 2 piece seal can be installed in a 1 piece block would be to spin up an alloy ring-split it so the 2 piece seal could be installed & then set the whole assy in the block with crank or press it in after crank installation , you would need to live out in the backblocks like me to go to that much trouble.
Jac Mac
