Thread: Headlights
Old 06-28-2010, 06:04 PM
BDR879 BDR879 is offline
Cobra Make, Engine: Backdraft 879, Indigo Blue / Wimbledon White, 428 Cobrajet, TKO 500
After my last post, I went out and checked and found the philips screw on the bottom of the bezel just like you said (I'm a master at overlooking the obvious ).
In any case, got the bezels off and pushed the car about 1 ft away from the wall, turned on the lights, marked a x in masking tape at the center of the beam, then backed it up about 15 ft (that's all the level surface I had). From there, I adjusted the lights using the adjustment screws. Left to right alignment looked pretty good....up and down adjustment was waaay off....but not anymore.
It looks alot better than before......
Thanks for all the suggestions.
