I'm not a Backdraft guy, but most electric fuel pumps are very simple - one wire to ground and one wire to power when it is switched on. A quick check is to run a jumper wire from the battery positive pole to the hot terminal on the pump. If you hear it run, the pump is ok electrically. You could use that to get home in an emergency. If the pump doesn't make noise (and the ground wire is OK), the pump is bad.
Tommy
Previously owned EM Cobra
