Old 07-05-2010, 06:35 PM
elmariachi elmariachi is offline
Originally Posted by Jerry Clayton View Post
what do you mean by two water pumps?
The original 12k mile Edelbrock and a freshly rebuilt Ford cast. Tenps are exactly the same with both.
Does it have underdrive pulleys on it???
20" 3000 cfm, same that was on it before. Pulleys are stock diameters.
By running at 80mph down the road you are doing three things---1--speeding up the water pump and thus coolant flow
2--forcing more air thru the radiator3--generating more voltage which will then run the fans better
But even at that, it will not run at the 160-175 it ran out down the road before the bypass hose failure.
