Old 07-06-2010, 07:39 AM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
Yeah it's moving along...somedays backwards...lol...but it's still moving. Got the steering column built, mounted and the u-joints and shaft all hooked up. Interior is getting close to being done. Not done like as in painted and all that...but the body work part of it at least. Last night I was working on mounting the oil pump...it's a tight fit trying to squeeze a 5 stage pump in with those 4" frame rails...lol. Still struggleing as to where Im going to mount the tank....Im thinking about over the passenger side header...back in that space between the footbox and wheel tub.
Hows yours coming along? Last time we talked your were thinking about changing the rear suspension.
Gene
" If it wont break em loose in 3rd gear, it aint enough power "
