I thought heat might be a culprit at first so I made some heat shields and covered them with reflective heat tape and shielded the clutch lines in the engine compartment. I then replaced my hydraulic fluid with high temp Wilwood fluid. No change.
Car is heading back to the installer for it's third trans-ectomy in a year. Will let you know what they find this time. Will probably be a couple of weeks.
Jim
