Ernie: That is why I differentiated between the black over-flow canister and the expansion tank in my original post.
Tim: Thanks for the input. I don't fill the expansion tank to full, however, it is possible it may have been slightly over-filled, and if the overflow tank was full already, it would have spewed out as it did. The valve at the bottom moves 90º open/close to drain the overflow tank, but the entire assembly rotates 360º. If is is press fit as you noted and not screwed in, it would explain the rotation.
Peace through superior firepower...or is it horsepower? Either way, more is always better!
