  #26 (permalink)
Old 07-07-2010, 10:56 AM
CBattaglia's Avatar
CBattaglia CBattaglia is offline
Cobra Make, Engine: Gary Edwards Racing 460
Originally Posted by mattpatt View Post
I've seen where the stock rubber mounts allow the engine to move around enough for the headers to hit the body and the poly mounts solves this. I'm planning on a 351W based engine (getting close to ordering car and, if new, the engine, etc.). Anyone tried these? How is the vibration insulation to the frame? I had a 240Z once that I changed the stock rubber sway-bar, etc. bushings to poly and they really transmitted road shock to the car.
I have a SPF with a 460. I also got body damage from the side pipes hitting. The rubber mounts couldnt handle the tourque. I think some guys shim one side up to compensate for the movement. I went with the poly mounts as well. It is the way to go. Not much additional vibration to the cockpit at all.
Its not the will to win that matters....Everyone has that. Its the will to prepare to win that matters.
