Old 07-07-2010, 11:36 AM
strictlypersonl strictlypersonl is offline
There's negligible toe change over the entire suspension movement. (It's nice to start off with a clean slate...) The camber change is only about 1/2 deg per inch, which is pretty standard for modern suspension. As the above posts suggest, I would look at the static toe-in (stick to the specs), the spring balance, and the tires.
