  #28 (permalink)
Old 07-08-2010, 03:52 PM
olddog olddog is offline
I noticed the dyno sheet said 30 deg timing. It is my theory that the shorter the distance from the spark plug to the far edge of the cylinder the less timing an engine needs. So does the Hemi design make its best power at significantly less timing or did you have to retard it due to the compression and pinging?
