07-09-2010, 07:04 AM
NH
We have some good brain power working here thanks guys. Bell is a QT and was absolutely spot on when indicated. I want to dive right in and check pilot bearing and flywheel bolts but I don't want to go right by the problem on the way in. I was thinking about running it with the flywheel off once I have it back apart. If the motor is adequately supported that seems feasible? I also have other flywheels to try on it. I will check what breed damper it is. That would be an easy change/test also wouldn't it?
