Thanks for all the input. Jay is correct. Once I got the car high enough off the ground, I found out one fuel pump terminals was loose. I tightened both press fit connectors and added a wire tie to keep them tight. I hope this does the trick. I'd like to see the connectors fasten with a nut rather than press fit, but it is what it is.
Thanks, Rick #794
