Originally Posted by BDR879
Thanks Jay and so noted.
My fan was not in the manual override position at any time.
Another Q for you though....If the battery cutoff switch is turned off and the key removed, doesn't that isolate the battery from any other power draws?
If you remove red flag key it is all off. Since you have installed a big old hot and bothered FE you may have some more heat to deal with. What starter are you using?
