  #32 (permalink)
Old 07-10-2010, 04:36 PM
DanEC's Avatar
DanEC DanEC is offline
I believe that a balancer on an internal-neutral balanced engine is there only to minimize harmonic type forces in the crankshaft. So, unless it is coming apart or the ring has shifter substantially, it's pretty unlikely it's causing an engine vibration problem. I think I would be looking at a problem in the original balance work, the flywheel/clutch assembly or a bad cylinder from a plug or wire.
