Finally after what seems like months (I guess it was!!) my car is back on the road! I finished the manifold and carb install yesterday and cranked it up for the first time after work today.
The car runs MUCH better; no dead cylinder, no missing. It is still a little lean at the transition (2200-2300 rpm) where I am getting some slight popping and sneezing. I am currently running .60 idles, .80 holders, 1.20 airs (changed from 2.05) 1.45 mains and F-16 E tubes (Changed from F-7). Mixture screws are all right at ¾ turns, fuel pressure 2.5 lbs.
I may try .65 idles an see if that richens up the transition…Any thoughts? Also, I think I need to set the floats as I know I am leaking some fuel past the butterflies after shut down. Any one know where I could buy a gauge?
Thanks,
Gun Doc
