Originally Posted by 67JET
After you get it all together and fit-up and make sure their are no issues i understand you also crank it before the build is over. Now what happens next? Is it ready to get liscened and drive , except for paint of course? I guess it would be up to the body shop or the owner to take it back apart for painting.
I'm a auto body man, and I believe like most Hot Rod Builders, to assemble it to run, take a short drive around the block to see if there's any engine & drive line issues. It's much,....easier to fix problems without the body on and you don't have to worry about scratching that expensive paint job !
I know it sound like too much work but, you'll be happy at the end, if you disassemble and the paint.
