  #48 (permalink)
Old 07-13-2010, 11:29 AM
mickmate's Avatar
mickmate mickmate is offline
I have run the motor with just the flywheel on it. Pretty good shaking (versus vibration) at 12-1400 rpm. At 2000 now it really smooths out. Removed the flywheel and spun on a wheel balance machine, it shows 0. With the clutch pressure plate on there it shows .25 oz unbalance. I have the clutch disc, PP and flywheel going to balance right now. We'll see what that reveals. Damper is tight on 3 allens and the centre bolt, all loctited on assembly. Timing is 16 deg and steady at idle so I'm thinking damper is OK.
mickmate
http://www.actoncustom.com/
