I had my machinist take a Chrsyler PCV valve (threaded) and mount it to al alum plate. He then took a 5.0 PCV breather (small wire mesh) and make a small cylinder of of steel with holes for it to breath. The assembly dropped into the back of my Blue thunder intake and was covered by the alum plate. This had a small rubber tube which went to my throttle plate. With the aircleaner on you can hardly see it. It was so trick! He could make you one.
His name is Tom Snay
508-882-3333
