07-17-2010, 08:28 PM
KY
Did you get in touch with McLeod? They should make good on the pressure plate.
As for Centerforce, I'd rather run an Autozone clutch than a Centerforce. I'm afraid you'll have more problems out of the C/F than anything else. The weights will more than likely have to be removed for proper behavior and I wouldn't count on it holding the power that the engine is making (with or without the counterweights).
If you do want to try something else, I would suggest a RAM clutch....but I would let McLeod make good on the current setup. McLeod is among the best of the best in my opinion.
