I couldn't remember the flywheel tooth count, but there it is, 157 tooth is the smaller diameter, 164 is the larger "standard" 351-W flywheel......bolt pattern on the crank/flywheel is the same for 302/351-W and both size flywheels, so it's a direct bolt-in deal........
David
DAVID GAGNARD
