Old 07-18-2010, 12:31 PM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make & Engine: DIY Coupe, F/T ,MkIV.
Smile
From what I understand this is for an ERA GT40?, & these cars per the ERA info have the coolant going from the outlet or T/Stat via this 'Tee' into the bottom of the header tank which appears to be mounted on the RHS firewall-beside #1 plug-. The 'Tee' is mounted between the water outlet & header tank & is also attached to the pipe going fwd to the radiator. Therefore the 'Cobra' type water neck will exit on the wrong side.
JP Fletch also posted this enquiry on GT40's, I was able to attach a dwg on that site, it wont upload here for some reason..
If Im correct he wants a simple single barbed 'Tee' fitting in alloy to suit a hose with 1.25" bore
Jac Mac
