Old 07-18-2010, 03:26 PM
dlampe's Avatar
dlampe dlampe is offline
Default Help with Haywire wiring harness
If anyone has a Haywire wiring harness could you send me a note? I have a question about the starter solenoid wire. The large purple solenoid wire enters the fuse box and comes back out but I have no connectivity between the wires. I don't have any blown fuses or none of the relays are marked for the starter solenoid. If I run a wire from the solenoid to my start button it works but the purple solenoid wire in the harness doesn't. Where does that wire go when it goes into the fuse box? I know one of those wires goes to the solenoid the other comes from my starter button. The button has 12v power. Can I just cut those wires and connect the wire that comes out to the wire that goes in and bypass the fuse box all together?
High Maintenance Racing Team
Run & Gun 2003 - 2013
