  #35 (permalink)
Old 07-19-2010, 11:36 AM
undy's Avatar
undy undy is offline
Originally Posted by Jerry Clayton View Post
And if you are going to pressure test the engine--you can do it one side at a time without removing the heads
Thanks Jerry, you're entirely right... I didn't even think about how the coolant passages do not go left to right, other than in the intake. That's what I call ADDED VALUE! That should narrow it down even further. Not seeing a FE coolant flow diagram I would assume the the right side water pump block entrance just feeds the right side of the block and visa versa for the left side.
As I'd said, I never had the froth until I had the coolant leak. It never produced the froth before for two years, with the other intake and the exact same ventilation system (2 breathers and a PCV) and the same finned valve covers.
Too many toys?? never!
