Sleeves work great if properly installed. Poorly installed causes problems. Lots of standard issue shops do not pay attention to what they are doing. Too tight a press causes cracks in the deck from the OD of the sleeve to an adjacent head bolt hole. Too loose or no limiting step will allow the sleeve to drift down under head gasket crush load.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
