Dot 5 is the problem. I quite running that long ago. I dought that you have reach the limit of the stock brakes they where designed for a car the weighs over 3200ish lbs you have reached the limit of the Dot 5 fluid. Castrol SRF is the way to go. When I switch to it I asked Reg about the DOT 5 spec for the brakes. He said not to worry and run the SRF...
Reason: adding
