  #50 (permalink)
Old 07-26-2010, 11:37 PM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Mickmate, Are you going to be producing & selling the components. I would consider installing Watts to my setup but seems like the only component that would fit readily would be the section that would bolt to the Jag hub carrier. My frame is different so I do not know if the heim joint rods would have to be made a different length. For sure the brackets that weld to my frame would be different.
Do you have prices?
Arthur
